S'inscrire
FAQ
Calendrier
Marquer les forums comme lus
MicroClick-Québec.ca
CENTRE DE DOCUMENTATION
Liens à faire connaître
Puran Defrag
Identifiant
Se souvenir de moi ?
Mot de passe
Merci de toujours commencer une question par une salutation et de remercier le futur aidant.
Partage de liens intéressants que vous trouvez sur le Web
ATTENTION : PAS DE LIEN MENANT À DES SITES PORNOGRAPHIQUES, DE HACK, WAREZ, P2P ET CIE
Outils de la discussion
22/03/2017, 11h15
1
Puran Defrag
http://www.puransoftware.com/Puran-Defrag-Download.html
Gratuit
22/03/2017, 11h28
2
Aimeric
Re : Puran Defrag
Disk Check Helps you to fix errors, recover bad sectors on your hard disk using chkdsk.
Uninstaller Helps you to uninstall software that you do not need and also software that you are not able to uninstall otherwise.
Puran Startup Manager Helps you to enable/disable Windows startup items. It assists your decision in various forms.
Puran Service Manager Helps you to enable/disable Windows services. It assists your decision in various forms.
Puran Disk Cleaner Helps you to find and delete junk files from your computer. It is highly customizable too.
Puran Delete Empty Folders Helps you to delete empty folders from your system. It is extremely fast.
Fix Shortcuts Helps you to automatically fix or delete broken shortcuts.
Puran Registry Cleaner Helps you to clean Windows registry for better performance.
Puran Registry Defrag Helps you to defrag and compact Windows registry for better performance.
Puran Defrag Helps you to automatically defrag and optimize your hard disk drives.
Puran Duplicate File Finder Helps you to find duplicate files on your computer. It is highly customizable and extremely fast.
Data Recovery Helps you to recover data from your damaged media like scratched DVDs, VCDs, BLU Rays etc.
Puran File Recovery Helps you to recover deleted files from your hard disk, pen drive, memory card. Basically any storage medium.
Disk Files Helps you to look into details of files distribution on your computer. It is highly customizable.
Gaming PC Helps you to create a Gaming Environment on your PC to give your games/apps best of your computer.
Permanent Delete Helps you to delete your files permanently so that they cannot be recovered by any software.
Puran Wipe Disk Helps you to wipe entire disk or just free space so that no files on it can be recovered.
Puran Shutdown Timer Helps you to schedule various shutdown tasks. Many scheduling options are available.
Splitter Helps you to spilt any file into files of specified size.
Delete History Helps you to delete history and other data of various applications including web browsers.
Minimal PC Helps you to close and switch back all the specified services/processes on your computer in a click.
Batch Fix Helps you to automatically keep your system clean and error free by running selected utilities.
Maintenance Wizard Helps you to run selected utilities in a pre-defined order for getting best performance out of your computer.
22/03/2017, 11h29
3
Re : Puran Defrag
moi je me sers uniquement du défragmenteur
Discussion précédente
Discussion suivante
Utilisateurs regardant la discussion actuelle : 1
(0 membre(s) et 1 invité(s))
Afficher une version imprimable
Envoyer un lien vers cette page par email
Choisir le mode hybride
Choisir le mode arborescent
Vous
ne pouvez pas
créer de nouvelles discussions
Vous
ne pouvez pas
envoyer des réponses
Vous
ne pouvez pas
envoyer des pièces jointes
Vous
ne pouvez pas
modifier vos messages
Les
balises BB
sont activées :
oui
Les
smileys
sont activés :
oui
La
balise [IMG]
est activée :
oui
Le code HTML peut être employé :
non
Règles du forum
Tableau de bord utilisateur
Messages privés
Abonnements
Utilisateurs actuellement connectés
Recherche dans les forums
Accueil des forums
Espace MicroClick-Québec
Règlements
Nouvelles et Annonces
Forum - VBulletin - Problème
PROBLÈMES TECHNIQUES
Internet et logiciels
Hardware (Matériel)
Réseau
Sécurité informatique
Désinfection
Questions, commentaires, solutions
Windows
XP - Vista - Windows 7 - Windows 8.1
Windows 10 - Windows 11
APPLE
Logiciels Macintosh et OS 15-16
Ipad - Iphone - Ipod - "IOS"
Boîte à outils
Trucs et astuces
Actualités informatiques
COUR DE RÉCRÉATION
Parlons-en
Santé - Espoir et Partage
In memoriam
Le grenier
Test
PAGE WEB - AUDIO/VIDÉO/TV-HD - PHOTO - TÉLÉPHONIE MOBILE - INFOGRAPHIE - TABLETTES - LISEUSES
Page Web
Audio/Vidéo/TV-HD 4K
Photos - Appareils photos
Téléphonie mobile - tablettes - liseuses
Fuseau horaire GMT -5. Il est actuellement
00h27
-- Default Style
-- tigra
-- Silver Blue
-- Smart Brown
-- English (US)
-- Français
Nous contacter
MicroClick-Quebec.ca
Archives
Haut de page
Version française #23 par
l'association vBulletin francophone
